Woke up and turned on the TV and a Car MD infomercial was on.
Basically, it's a very dumbed down OBDII scanner you can plug into your computer to get a "quote" for the repair. A guesstimate based on the codes pulled.
It's clearly targeted towards idiots based on the people in the infomercial. And it can definitely be wrong. An OBDII code usually tells you part of the problem, it's a starting point for a diagnosis. Had I used Car MD to diagnose my truck's check engine light, I would have replaced a charcoal canister instead of hooking up the vacuum line that came loose, a free five minute repair.
What a bad idea, especially for $160.
