Just noticed low coolant in surge tank. Truck had been in to a shop for exhaust manifold gasket replacement and they did drain out some coolant. Level was fine when I picked up the truck from the shop. a couple of weeks ago
When I noticed the low coolant level I checked the cap and saw that the shop had not tightened it. I wonder if that might have caused the coolant loss. I don't think the coolant would have boiled over because it has a low temperature thermostat. Coolant temperature
had always maxed out at around 180F. Engine is a 2006 CAT C7.
Perhaps it was trapped air in the system working its way out. I can't see the coolant sloshing around so much in the tank that it would leak past the loose cap and then drain through the overflow hose. There are no signs of any spilled coolant anywhere.
