Would 10w-30 ever be better than 5w-30?
Bay Area, CA
This is a bit of a novice question.
Assuming good oil quality and equal top numbers, would an oil with a higher lower number ever be better than one with a lower number?
So, let's say 5w30 versus 10w30.
My understanding is both protect with the same viscosity on the high temp end. Yet, the 5w is more fluid at low temp, this offering better protection at lower temperature?
Am I thinking about this the right way?
In other words, what advantage would a 10w30 have over a 5w30?
Thanks.
10w30 will have a lower Noack %, less viscosity improvers. If you get synthetic 10w30, it will have a viscosity range near to 5w30.
Specially dino. That why Honda recommends only 10W30 for S2000, until the model year 2005 they recommend 10W30 for temp above 0F and 5W40 for temp below 0F.
Especially in a conventional it would be less volatile (noack) and less prone to shear. Modern oils this isn't a much of a concern, and with "synthetics" even cheap group 3 ones it makes it even less so. But 10~20 years ago it was significant.
I guess it depends if you were more likely to have cold start wear of shearing out of grade, but realistically they're more or less interchangeable at this point. Other minor issues like short trip fuel economy and HTHS might also be a factor one way or another.
Thanks.
Depends.
For example, it's possible to have a 5w30 or even a 0w30 with no viscosity index improvers (VIIs). That means it would have very high quality base stocks, which is a good thing in every way. In that case, you most likely wouldn't see an advantage to a 10w30.
For most synthetics, even the ones that do require some VIIs in 5w30 or 0w-30, there may be some advantages to a 10w30. However, 9 times out of 10, those will be so slight that they will be outweighed by the disadvantage in cold pumpability.
On the other hand, if you're looking at conventional oils, even good ones, then the advantages and disadvantages mentioned by other posters (volatility, shear stability, etc.) would usually apply.
Thanks.
No advantage if you are talking about Group III and higher oils. On the Group IIs, the 10w30 would be safer for Direct Injection engines
Thanks.
According to this MAGNIFICENT FAQ, you want the "Thinnest Oil Possible."
Basically, it states that 5w30 is the same as 10w30 when Warmed, but VASTLY (!!!) Better at Start-up than a Honey-like Oil.. referring to any 40 or 50-weight.
He says "People think the Oil Tghinning as it gets Hot is the issue. in reality, the oil Thickening as it Cools is the issue."
90% of Engine Wear occurs at Start-up...
Who agrees with this? Making me feel MUCh better about 10w30 in minw, maybe even 5w30 all year !((() but i just read "Too Low" Oil Pressure can mean your Film is breaking down..
is 40PSI TOO LOW an Oil Pressure, where your Oil Film is at ricsk of breaking down.. at 3000RPM on a 5000RPM Redline Engine?
Here is the FAQ.. Hes bascially saying "Use Synthetic 5w30 for Everything" and im thinking if i will do this, i WAS gonna use 5W-50 and i still may...
http://ferrarichat.com/forum/faq.php?s=0...otor_oil_basics
http://ferrarichat.com/forum/faq.php?faq=new_faq_item#faq_haas_articles
Thanks.
What is your obsession with shouting and punctuation abuse? Do a search for Haas. He's been discussed before.
Also, please dramatically reduce the size of the picture in your signature so that it doesn't take up the entire screen. Better yet, just provide a link to the picture instead. No one wants to look at your Jaguar each time you post in a thread.
