JHZR2
Staff member
Those... what good are they? Yeah, I know they’re roughly the same as Mini DisplayPort. But I have no need for that. I would like another standard USB port, but are not finding adapters.
Is this port just useless at this point?
What was its original intended use?View attachment 37547
One quick thing-since you have two I'm assuming these are on a Retina MBP. That makes them Thunderbolt 2.
Second-they still have a lot of potential. Among other things, not too long ago I used TB to clone one Mac over to another with one in target disk mode. That's a handy one.
External storage over TB can be crazy fast.
One of the big ones that I've never done, but interests me, is eGPUs. They're not officially supported over TB1/2, but they're easy to make supported.
With appropriate adapters/cables, TB3 peripherals can be connected to these ports.
Apple included a Thunderbolt controller in their M1 chips, as well as support for USB4. Thunderbolt 3 and 4 as well as USB4 require USB-C connectors. Intel also is allowing pretty much anyone who wants to use Thunderbolt to do so, there are even a few AMD motherboards out there with thunderbolt.I bought a docking bay for my Thinkpad 25 that uses Thunderbolt 3. That puts a lot of different signals across that one interface, as compared to the legacy method of a 80 or so pin connector on the bottom of the laptop.
Drawback is it's an Intel chip thing, from what I read, so what is Apple going to use on the M1 chip laptops? USB-C?
Dell, HP, Lenovo, LG and Samsung make USB-C monitors, and Thunderbolt 3(or USB-C DisplayPort Alt Mode) can drive a 4K-5K display with little issue, as long as you have the GPU to do so. The nice part about the USB-C monitors is they are almost like a docking station. One cable for power(at least 45W, Dell promises 65W on their monitors), data(USB 3) and display(usually DisplayPort, there is also an HDMI Alt Mode supported by some USB-C Alt Mode setups). Not all USB-C ports support the DP/HDMI Alt Mode, USB-Power Delivery or USB 3.x speeds.Yes, I realized after that they are thunderbolt 2.
I recognize that speed wise there is potential. But I am unable to find so much as a Thunderbolt to USB adapter that would let me use these. The gender always seems to be wrong. There are one or two $99 adapters that give a usb 3 and HDMI port. Id take the USB 3 even without speed advantage, but not for $99.
So how does one actually put these into use? Where do you find a male thunderbolt 2 to usb a or usb c or something else useful?
It's ancient now, and I wish it had been updated, but one of my favorite Apple peripherals of all time was the Thunderbolt display.
Back when Apple was really the only one using TB(in 2011) they rolled out a 27" display with the same panel as the 27" iMac and the 27" Cinema display. Aside from power, the display cable split out into two connectors, one Thunderbolt and one a Magsafe(1) charger. The back of the display had 4x USB 2.0, Firewire 800, Gigabit ethernet, and another TB port to allow daisy chaining. I would have loved to see Apple update it with USB 3.0(esp. since the first TB Macs didn't have USB 3.0) and maybe the 27" Retina panel.
There were a few other attempts at a TB1 dock-I think Belkin made one. They did similar things, but lacked the display.
TB is now really coming into its own, and again has a ton of potential.
Is this your only Mac?But it doesn’t look like I can get the TB2 ports to be useful without again more claptrap or a $99-type adapter that only yields one more USB port...
Everything I look at has a female TB 2 connection, nothing with a USB hub/drive enclosure/etc with a male TB2 cable. Maybe thats on purpose and TB 2 is always male-male cables?
Apparently it doesn’t. It seems like this thing is one way only.Yes, normally you'd use male-male connectors. There are several ways that it has a passing similarity to Firewire.
In any case, this adapter https://www.apple.com/shop/product/MMEL2AM/A/thunderbolt-3-usb-c-to-thunderbolt-2-adapter will let you connect to TB-3 peripherals.
