Last month, I did a 75k service on a Volvo S40 T5 for someone for the cost of parts. I thought it would be a quick and easy adventure...
As I learned the hard way, nothing on a Volvo is truly easy.
The cabin filter on this car was truly a nightmare.
First, you had to remove a couple panels under the steering column.
Then, you had to remove the 3 lock-nuts that held down the accelerator pedal. In addition to the nuts being in unreachable places, the nuts do not unscrew by hand - so you have to sit there with a ratchet and slowly unscrew them.
Next, you get to remove the three 7mm bolts that hold the cover on.
Finally, you get to reassemble this whole mess and pray that you did not break anything in the process. I'm sure a dealer tech who does a lot of these can get it done in 15-20 minutes, but it certainly took me a lot longer than 0.8 hours that the book time pays!
/end rant
Untitled by thecritic89, on Flickr
Happy Wrenching,
The Critic
/end rant
Happy Wrenching,
The Critic
