Wondering if this tree will survive..
GON
$150 Site Donor 2025
White Sands, NM
When we bought this home 11 months ago, this palm tree was laying horizontal. The tree was horizontal in the real estate listing photos.
I assumed the tree had shifted after planting, and grew horizontal. Went to trim some dead branches from the tree today, and to my surprise the tree had a ton of play.
I placed the trunk vertical. Tied down the trunk to a stake, and placed 20 lbs of topsoil in a void at the trunk. I suspect the tree was planted with one side missing topsoil, allowing the collapse.
The question now is- will this tree recover?
Does the inside or roots look like they were brittle or rotted out? If not I'd use a healthy dose of revive or a fertilizer made for trees, and you should be good to go. It'll definitely need support upright for a couple of years if I had to guess.
Never heard of revive. Thanks for the recommendation.
Not sure how to judge the exposed roots..all I can share is the tree was horizontal for at least 15 months, and when I removed some rocks around the trunk I saw roots that appeared to be living, yet not anchored into the ground.
Wild guess is this specie of tree is pretty hardy..but just a wild guess.
Find out what the watering schedule is for palm trees. It will vary by time of year and temperature, rainfall, etc. Also apparently there is specific palm tree fertilizer. It looks healthy so if you didn't break the roots setting it up I'd bet it will do fine.
The question now is- will this tree recover?View attachment 293141
https://www.treehelp.com/
I've been fertilizing a very old, dying Elm Tree for a couple of years with Tree Help's Elm Tree fertilizer and this summer it has more leaves than it's had in years. It might actually live a few more years. I was think it would have to be removed by now. It's over 100 years old.
I don't know if they have fertilizer specific to your palm, but it's worth a look.
  • Like
Reactions: GON
Fascinating- learn something new every day.
And to supplement your post:
Why is Florida not planting palm trees?​
This is an important note about the average palm in southern Florida only absorbing 5 pounds of CO2 per year. Compared to other trees – oaks, mahogany, pines, and cedars – that can sequester more than 3,000 pounds of CO2 over their lifetime, it may be best to exclude palms in favor of more broadleaf trees or conifers.
https://texastreesurgeons.com/blog/2025/01/03/palm-trees-are-not-trees/
