I find this data confusing: The regular WIX 51515 filter, 99% at 23 um should capture much more material by weight & many more particles by particle counting as it capturing 99% of all the particles larger than 23 um vs 99% of only the particles larger than 35 um. I understand that the particles larger than 35 um will be much heavier than the particles sizes between 23 um and 35 um.Laboratory Test Performance per ISO 454812 18 grams dirt (WIX 51515), 99% efficient at 23 microns (Based on WIX 51515, WIX 51356, WIX 57060).
Oil Filter Laboratory Test Performance per ISO 454812 32 grams dirt (51515XP), 99% efficient at 35 microns (Based on 51515XP 51356XP, 57060XP)
Could someone explain the variation of the ISO 454812 Test Data and the Data from the the WIX site expressing the Beta Ratio:2/20=6/20?
The WIX.com data sheet for a regular 51515 Oil Filter is expressed as Beta Ratio: 2/20=6/20. This is 50% Efficient at 6 um and respectively 95% at 20 um. WIX does not provide an Oil Filter Efficiency for the 51515XP, seems odd given this filter is much more expensive and they are not providing the Beta Ratio Data Sheet.
