wix filters good for both conventional and synthet
LBP
This might be a stupid question but I wanted to know if my wix oil filters that i'm using are good for both conventional and sythetic oil because I was at my auto parts store recently and I saw fram has a filter for both oils?
Repeat after me.....
M A R K E T I N G...
It does not matter what oil you use for any filter.
Your WIX could care less. If you see a filter that says it is for a certain brand of oil or type, run away. Do not reward the dumb marketing!
Take care, bill
I thought so, but I just wanted to make sure. I have learned something new and I will pass it on to those who like me who before didn't know
thanks
Any filter can be used with any oil.
Wix is a GREAT filter. One of the better one out there. Use with no worries!!!!
Odd, the Fram isn't good for conventional or synthetic oils.
lol
Good one
Originally Posted By: labman
Yeah, hype. Like synthetic brake fluid.
Syn brake fluid in my opinion is better. It has better lubrication properties for brake-force distribution units used in many traction control / ABS units... I feel their is a difference and money well spent. It keeps them from corroding and absorbing moisture in the lines... These units are very costly to replace.
I have used WIX in the past with synthetics and it worked just as good... Then I found AMSOIL Filters to have the best filtration in my application so I'm using them. Doesn't really matter. UOA proves everything not marketing..
Originally Posted By: FleetFilter.com
Check us out for WIX filters. We have a great price on them.
Bryan
please tell me what WIX filter would replace the Mobil M1-301 or a Pulator Pure One PL 30001
Bryan
Wix 51515.
Originally Posted By: RWEST
As ThirdeYe noted, it's the 51515 (or NAPA 1515). That's the MotorCraft FL1A replacement, so it fits a BUNCH of things.
BTW - Everyone should have the WIX conversion chart saved in their favorites - http://www.wixfilters.com/filterlookup/index.asp
I have the Donaldson one in mine
https://dynamic.donaldson.com/webc/WebStore/search/cross_reference.html?functionCode=WEBC_XREF
