I installed the Driveimage XML plug-in into BartPE using PE builder, and this added Windows Disk Management to my programs list. Every time I go to use it in Bart PE, the CD spins up but nothing ever happens, however Driveimage XML works perfectly. Were there other plug-ins that were needed to make this work?
I've done this with the newest Driveimage XML plug-in, along with an older one as well. And during the PE builder process, when you select the plug-ins to disabe/enable, Windows Disk Management is not listed.
Any help is appreciated.
