Window AC styrofoam block always molds
Wisconsin
These window AC units seem to get one year then the styrofoam block inside fills with black mold.
This despite having the filter cleaned often and being blow out cleaned and dried.
I can’t find a way to tear down to the styrofoam block, how do I keep from having to toss a unit because inaccessible areas turn to mold?
would those tablets help out that are basically bleach tablets you drop into the condensate pan. Wondering if that would stop the styrofoam from absorbing all the water? Or you could see if you could spray the styrofoam with an anti-mold or anti-mildew solution to stop that..
Ive taken the top off of several of them and just hosed them out with a garden hose. Obviously try not to spray into the motors or controls and let it sit and dry awhile before turning it back on.
Yeah I have a tooth water pick I used to spray them out with a leaf blower to dry outside on the last unit last year, I just cleaned as best I could using paper towels then ozium, wait then paper towels. But still tons of mold on the fan and inaccessible places.
Ran UVC in there about 10 minutes.
Now sadly had to have empty room and open windows ventilating overnight (68F and 90% humidity bleh)
Hopefully the ozium stink is aired out after being empty 16 hours
Sadly cleaning a window ac usually just instantly molds up again in a short time
