I was only searching "motor oil grade temp chart" when I stumbled on to this message board.
"post Jun 1 2005, 09:57 AM
Post #3
Drives: Hyundai Accent Elegance 1,3 12V SOHC 62kW, Model 2005
QUOTE
My owners manual says if temps are to remain above 0F and expected temps to 100F, use 5 or 10w30. If you go to the Hyundai hmaservice site, it says if temps over 100F, 10w40 would be appropriate.
My concern is that in this small 2.0L 4cyl, high revs and high temps may need the 10w40 for proper protection and I won't be using it. Hyundai should have been able to give me an answer.
Yes, they SHOULD have
Please DEFINITELY GO with 10w40 - if not with 10w50 !!!!
The recommended temperature range are as follows
10w30: -13 F to 100 F (-25Celsius to 38Celsius)
10w40: -13 F to no limit (-25Celsius to no limit)
In other words the difference between the two oils You are hesitating is, the 10w40 has same performance at low temperatures, but works well also above 38C/100F
Attention!
5w40 is for cold climate !!! only below 68F/20C
Source HMA table - Recommended SAE viscosity number by temp."
Is this Hyundai from the moon? What is wrong with 5w-40?
Post #3
QUOTE
Attention!
