Now if you look at the manual you will probably see at least three different grades of oil for your vehicle based on outside temperature.
Not for the two cars I have i.e. both are GMs and the manuals for both specify only 5W30 and
barely permit 0W30 (only if the temperature falls below -20F).
That's something new to me. Are these newer cars? Hard to believe you can only run a 0w30 below -20F. Maybe they know something we dont.
I wasn't clear. You can use 5W30 for
any temperature but have the option of using 0W30 if the ambient temperature is below -20F. No other grade of oil is
permitted according to the manual.
And these instructions are the same for our 05 Pontiac and 09 Chevrolet.
Are you saying that this is IN PRINT (that paraphrased dialog)? Most have those arrows/bars of suitability on a temp chart.
I can only imagine the 0w30 extending beyond on where it begins compared to where the others do. The "finish line" should be the same.
I could see it saying "where temps are at or below -20F, a 0w30 is suitable for use".
That in no way prohibits its use 24/7/365. That's not how that's to be interpreted.
