Originally Posted By: Shannow
Originally Posted By: Nyogtha
If the ADBV isn't working properly, the filter orientation might make a difference in filter size vs. how quickly oil pressure develops. For example, if the filter is vertically mounted dome side down, there should be no difference. If the filter is mounted dome downward at an angle between horizontal & vertical, then the volume emptied of motor oil by the faulty ADBV may be variable with oil filter case size.
The oil in the galleries will still drain down regardless of ADBV, and require refilling. There's literally nothing holding it in the galleries, potential for air to get in the cam bearings, and the mains being open mean that they will drain down over time.
If the filter is above the crank centreline, then at any orientation other than gasket up, the filter can drain down over time regardless of the ADBV being faulty or not.
When Holden had their 1960s developed 6 moving into the 80s, they dropped the filter size greatly to reduce hydraulic lifter noise by whole numbers of seconds.
Oil pump driven off cam, with the filter horizontal meant that it drained down quite quickly.
But over what time frame in most modern vehicles?
Minutes?
Hours?
Days?
Weeks?
Months?
I think most cars are designed to be daily drivers, and their oil filters designed to serve daily drivers. I have my share of experience with oil filters that drain back overnight as well as those who don't drain back overnight.
Or is this more of an issue for a vehicle driven quite infrequently, thereby showing a well functioning ADBV provides value for a typical modern daily driver in minimizing the volume to be refilled exclusive of oil filter case size?
My wife's 2011 Mustang 3.6L V6 has a horizontally mounted filter on the front of the block and doesn't have daily startup clatter with the spec'd 5W-20 and a Mobil 1 oil filter. The Mobil 1 M1-212 has the largest case size of compatible filters for this engine.
I've never owned a Holden, nor did my dad. Not likely to either.
