quote:
Originally posted by widman:
make sure they are equal in other ccharacteristics:
unDummy: the ph3682 depends on the relief valve in the engine or adapter. It has none. The ph3600 has it's own relief valve... don't know if the pressure are the same. they also use a different sized gasket, so you don't have the same seal.
Scot P: the ph47 has metric threads and the ph52 has 1" threads. They use different gaskets, and the ph47 has an anti-drain valve that the ph52 does not have. so if you put the ph52 horizonally, or on top, it will drain dry.
