I ask only because PS is a hydraulic system not some automatic transmission with clutches.
So it is sealed(to a point). Now I understand the cleaning abilities of ATF so is that the reason?
I ask because we have a piece of equipment at work that is purely hydraulic and indoors. It is a scissor lift that uses hydraulics to lift and move the unit. It has a very large tank for the system. Inscribed right on top is "Use Dexron ATF III only". I found that curious consider none of our other lift trucks call for that. This unit was filtered as well just as any other.
I am wondering if it is only for ease of obtaining the fluid for dealers/ind/owners that if they speced something like CH11S nobody would bother to change it or use it and then cause problems.
It then got me thinking can I used CH11S if I totally flush the system out? Would the pump/rack even care?
Just thinking out loud.
