Originally Posted by Paul_Siu
I notice that my car manual said to replace spark plug every 60,000 miles or 60 months. Why would there be a time interval replacement schedule. Spark plugs are made of ceramic and metal. I don't see it going bad over time if you don't drive a lot of miles like tires.
Paul
When your engine was designed the engineers chose a specific type of spark plug with an average useful lifespan in this application. Without pulling spark plugs you can't evaluate their exact condition. If you go to the trouble of removing them you may as well replace them. I'm not a fan of putting used spark plugs back in because the crush washers are ideally one-time use only. Yes, you "can" reuse a used spark plug. As has been mentioned the longer spark plugs remain in the head, the more likely the threads will seize. I have never noticed galvanic corrosion but I suppose in a very humid or wet climate that can become an issue. In a dry climate, in the absence of an electrolyte, I don't see how galvanic corrosion could become be a problem. I follow the manufacturer's recommended interval for replacing spark plugs. I also replace spark plug wires, where still applicable, every 120k miles.
