Originally Posted by StevieC
Did I claim otherwise?
Did I claim that you claimed otherwise ???
I was making a general post in a thread.
However, the clown in the video DID use a strawman with regard to stainless rebar that there wasn't enough to replace all the rebar with stainless...to which...
The vast majority of reinforced concrete, an alkaline cementitious matrix does more than just fine with regular old rebar...the VAST majority.
In specific locations/applications, it's inadequate..
Carbonation is a common issue, and it's poor design and construction (lack of cover), or poor concrete...design it right, and plain old rebar works just fine.
Stainless carries with it the potential for stress corrosion cracking in chloride environments (can be initiated with a chloride containing paint marker), or the creation of corrosion cells by simply bumping It against a piece of regular steel (the marks need to be passivated with stuff like hydrofluoric acid to prevent future corrosion...just like chipped epoxy.
The vast majority of your perceived attacks from me initiate in your head.
