Originally Posted By: ltslimjim
I get two "OE" temps for my VX. One is 180F and another is 170F, what gives?! lol
Imperial numbers? Those aren't OE. They aftermarket being marketed under a name that fools people into thinking they're the same as Original Equipment (OE).
Genuine-Honda OE will likely be made by Nippon Thermostat Company (NTC), and will be stamped with a Metric temperature. These are ONLY available at your Honda dealer, for about $35 each. Do not use aftermarket thermostats in your Honda, especially if it has an automatic transmission.
The 78C(172F) thermostat is for all engines but the D15Z1. The 82C (180F) one is for the D15Z1. I think your VX has the D15Z1. Check the engine number. It's on little flat pad on the forward edge of the block, under the head, between the transmission housing and the exhaust manifold. Might have to clean off the dirt first; the number can be hard to read on older engines.
