JHZR2
Staff member
Hello,
On our 94 previa (219k), the original battery (panasonic) lasted over 10 years without issue. It was replaced with an interstate and then again, due to a loss of charge.
The alternator seems to work fine. 14.3V is the output at idle under 50F or so temperatures.
The only battery that has not had significant white residue and powder around the terminals, at the clamp-down points, etc., was the original. I noticed what looked like white powder that looks like it has "flowed" down the positive wire in liquid state then dried up and left streaks.
So, I have to wonder if there are circumstances where the alternator intermittently goes too high in voltage and causes the battery to get hot and start to release. This is being watched on a 100 mile drive as I type this.
Interstate batteries seem to be some of the best out there. Obviously there is an issue that causes this junk to come out of the battery. Some cars seem to get this, others never do... My truck definitely puts out 14.4V or so under most conditions, and never a sign of any powder or residue.
So, what REALLY causes these white powder residues to form? Does replacement of the alternator tend to help? Can the regulator create issues that are unseen due to easy/fine starting power from the battery and "good" voltage levels?
Thanks in advance!
Thanks in advance!
