Car is an '04 Subaru STi that uses DEXIII as PS fluid. Last time I changed the fluid in the car for the owner, I used Amsoil Uni. ATF.
Car is currently back for it's 60K maintenance, and a PS flush is on the list. This time I had Amsoils PS fluid so I used that as a replacement.
Upon starting the car had a new whine that got worse with any wheel movement. Checking the fluid after shutting the car off showed a lot of foam. To the point of it being an inch above the MAX line on the reservoir. I evacuated the fluid twice with a 30 sec run in between with Uni. ATF and the whine and foam is gone.
WTH!?!?!
WTH!?!?!
