Which transmission do I have? Time to service.
Charlotte, NC
How do I tell which 4AT is in the truck?
Usually the dealer can tell by the vin # or the ID tag on the side of the transmission. W/O knowing all you'll be doing is guessing. My Ford transmission has an ID tag on the drivers side of it. HTH
For starters look at the shape of your pan, its holes, and compare to the gasket pictures.
If the 4R75W is a beefy 4R70W, though, these two could look the same. A check on rock auto shows the same filter and gasket for both transmissions, so should be mox-nix.
Since you have the 351 you should have mostly other heavy duty stuff. I suspect amazon's part finder is not that intelligent and is offering stuff for all F150s, despite that your motor may only be in front of a couple options. Try rockauto and getting part numbers.
Well, you could drop the pan and take your filter to a parts store and get the one that is similar. But since it seems like you don't want to give your vehicle any down time, write down your VIN, give it to the Ford parts man and buy your filter there.
My vehicles are both Chrysler and the dealer printed out by VIN# everything that went into the vehicle at the factory. Quite extensive. I suspect other brands have something similar and can give it to you if you stop in. No cost.
Originally Posted By: gr8gatzby
That's darn near $90 in Mercon 5 fluid.
Yup. Sounds about right. FWIW Valvoline makes a great Full Synthetic Mercon V ATF. Napa carries it.
I recommend going to a Ford dealer to get the pan and gasket because:
1. They would be able to find the right part on the first try using the VIN and/or calibration code.
2. OEM pan gaskets are usually far better than what you get from most part stores. The filter may also be better.
What's the required fluid weight for the E4OD?
Might say on the dipstick, if not it WILL in the manual. 1995 is right when Ford was switching from Dexron-Mercon to Mercon V.
I can't find it on Valvoline's web site...all I see is their unlicensed "ATF for Mercon V Applications" product.
Yep. And odds are, the filter and gasket will not be made in a country like Viet Nam.
