Which Schaeffers for what?
Georgia
Which Schaeffers should I use for the following?
1. Travel Trailer with Dexter EZ lube axels
2. Boat trailer
3. Finish mower
4. Tractor chassis
5. Duramax chassis
I have on hand some 221 and 274
What is the difference between 221-2 and 274-2??
I am using 238 for my Duramax chassis and it almost seems a bit too heavy. I have 3 tubes of it though, so I will use it up and try one of these.
221 is stickier. 274 is softer and better in the cold.
I'd use 238 for ball joints and drive shaft splines, but not for needle bearings in U-joints. It is so stiff that it won't flow into small bearings, including pickup truck size wheel bearings.
Ken
