which oil? or oils?
louisiana
Ok i have 3 04 z71 with 232000 94 ford ranger 238000 motor was just rebuilt and 07 toyota camry with 65000
the z71 burns 1 to 1 1/2 quarts every 3 to 4k mc 5w30 sy blend
just got ranger and camry was wondering if there is an oil that can be used for all 3
was thinking about Castrol GTX high mileage for the z and regular GTX for the other 2 or is it ok to use HM for all 3
Definitely Ok to use the HM for all. I personally would use Mobil 1 High Mileage then if I couldn't get ahold of that, Valvoline Maxlife. But use whatever you want and can afford. Use HM in all of 'em if you want, no problem.
isnt Mobil 1 a synthetic didnt think that would be a good idea with it burning it like it is what do yall think about the mobil clean 5000 or 7500 and the mobil clean hm
The Mobil Clean oils are very good. I would go for Mobil Clean 5000. I'm not a fan of High Mileage oils.
I would not worry about 1 to 11/2 consumption in 3K. Sounds like a Auto-Rx is in order. You could use a HM with no problems and it may help with your consumption problem.
