Which oil would be best for mixing with VSOT?
I've concluded that VSOT is a cost efficient way for have a high moly content in my honda. Using redline in my oil burner simply is NOT cost efficient.
(Isn't it odd that the additives with 'moly' in the title contain less moly than VSOT?
Which oil shall i use to mix with VSOT? I want to go heavy on the moly but don't want to go heavy on the calcim, phosphorus & zinc. I'm thinking that the ideal would be an oil that doesn't have any add pack whatsoever. That would eliminate the possibility of me goofing up the existing chemistry. (there wouldn't be any existing chemistry) Do they make a cheap 20W50 non-detergent oil?
Or does someone know of another way that i can get a cheap high-moly oil for my somker?
