which oil for 5.2L
minot nd
I have a 98 dodge dakota with the 5.2 V8 which oil would work best, expecially for cold weather, but one that would work good year round. thanks for any suggestions
I just bought a 2003 Durango with the 4.7L. I've got about 1200 miles on Mobil Drive Clean 5w30 GF-4. Doesn't get too cold around here. High 40's F. But I'm sure this oil will pour at very cold temps. Very quiet starts. Motorcraft 5w30 synthetic blend is a great choice as well. Others like HDEO oils such as 5W-40 Shell Rotella, Mobil Delvac, and Chevron Delo. When I hit the 3K mark, gonna switch over to Mobil 1 10w30.
[ December 22, 2004, 03:25 AM: Message edited by: ROM ]
quote:
I am having good luck with Kendall GT-1 synthetic 10w30 in a 5.3 V8 Chevy. Temps have been getitng slightly below freezing this year.
Bob W.
Heyjay might have some good tips for you. He's familiar with your climate conditions. You'll get a lot of feedback here, but everybody doesn't understand North Dakota weather like they do oil. I wouldn't run Mobil 1 0W-40 in your climate except in the warmer months maybe.
I think GC 0w30 would work year around for you. Of course with your Winters, I hope you have a garage, block heater, oil pan heater, etc.,etc. anyway.
If not and it's bad this year, maybe Mobil 1 0w30 for Winter season and Mobil 1 10w30 with some 15W-50 added for Summer.
At any rate a 0w30 syn with Winter coming for sure.
This is the single best analysis I have ever seen for that engine.
quote:
Russ_Knize Member #2184
These are very good numbers. This will be my new mainstay oil.
EQUIPMENT MAKE: Dodge, 01 Ram
EQUIPMENT MODEL: 5.2L 8 cyl
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 5,017 Miles
OIL TYPE & GRADE: Castrol Syntec Blend 10w30
MAKE-UP OIL ADDED: 0 qts
MI/HR ON UNIT 14,177 mi.
ALUMINUM 1
CHROMIUM 0
IRON 2
COPPER 1
LEAD 2
TIN 1
MOLYBDENUM 69
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 3
SILICON 5
SODIUM 4
CALCIUM 2869
MAGNESIUM 12
PHOSPHORUS 814
ZINC 993
BARIUM 0
SUS viscosity 64.6
Flashpoint 435
Fuel% >0.3
Antifreeze% 0
Water% 0
Insolubles 0.2
TBN 4.0
In Alabama this would be my first oil to try in this engine.
The year round oil for a climate with a record low of -49&#176F would be 0w30 Mobil 1 in my opinion. Just make sure you put in fresh oil around December 1. If your oil temp is always at least -22&#176F at start you could give Syntec 5w30 Blend a try.
Gene
[ December 25, 2004, 01:24 PM: Message edited by: Gene K ]
I had a '93 V8 Dakota and I let it go at 135K miles over a year ago and it was on a diet of 10w30 Castrol GTX except for last 10K I went to 10w-40 to keep the oil pressure a bit higher. Didn't use a lick of oil and I saw it again today still cruising around town. 3-4K on the OCI over it's life. Last check with a real oil pressure gauge it was 60 lbs even at idle.
My grandpa is an all out dodge fan but I think that he has started to lean more to ford these a day. He has owned several 318's in his life. All he has ever used is Quacker State 20W-20. I am not sure why they just don't call it straight 20. But I have been changing the oil in his truck the last few years. This truck loves my diet of 10w30 in the winter here in michigan and a 15w40 in the summer. I think you would have no problem with a 10w30 or even a 10W-40 year around but as for me I like the extra insurance of the 15w40 in the summer.
quote:
JR, keep in mind the climate extemeties. The oils you suggest would be solid at the temperatures he might experience. He could realistically see -40F out there. You might be further North geographically, but....it's a big difference.
Gene K, I like the Sytec Blend.
I'm just afraid that because we don't know what the Winter holds that I can't in good concience recommend anything but Mobil 1 0w30 or an Artic oil.
