Which Hydraulic Fluid is Best ?
Ohio, U.S.A.
The hydraulic fluid in our used 1996 Gravely 20G garden tractor is "black" color -- Would it be advisable to use: 1. "synthetic" Dextrom II or III fluid or "standard" Dextron II or III?
Eckville, Alberta
I would imagine that a garden tractor isn't going to get used in very much sub-freezing temperatures. For that reason I would run a standard or non-synthetic fluid.
Millbrae, CA
THF is better for a trans/hydraulic/gear box common system if your tractor is only the hydrualic end then use a good AW 32 hydrualic oil. bruce
