Reading the manual for my ramcharger and it says i can use engine oil or gear oil in the np 435 tranny. If temps are above 32 then use straight 50 weight motor oil. If below 32 use 30 weight motor oil. If temps are -10 or above use 90 weight gear oil. if temps are above 90 then use 140 weight gear oil. Hmm i thought all maual trannys used gear oil but that is not the case. That is quite a spread in viscosity for lubricants in any application. 90 wt at 0 degrees would be very thick till the tranny warms it up where as 30 wt would be ok at 0 but would thin out as the tranny warms up. What is the deal?
