Which clear sealer & top coat for basement utility room floor?
NJ
I have a finished basement with one side exiting at ground level. The boiler room, 6'x10', and the electrical room 4'x6' floors were left bare.
The boiler room has a sump pump hole, the electrical room does not.
I want to put on a clear concrete sealer and finish to reduce the dust and ease of mopping.
Home Depot? Lowe's? Sherwin Williams? Products?
I was going to prep wash using Simple Green, then use a acid? Non-stop etching solution? The acid would be impossible in the electrical room. Then hose in to the sump pump hole, the other room wet vac. Then put a dehumidifier in the rooms to dry out, for how long before I apply the finish with a roller.
Use a sealer made by the company that makes paints for the U.S. Navy, Boeing, offshore drilling rigs... . Go to a PPG paint store.
https://www.ppgpaints.com/products/...terior-exterior-clear-sealer#data-sheets
https://www.ppgpmc.com/Home.aspx
Perma-Crete Plex-Seal WB Interior/Exterior Clear Sealer 4-6200XI is
a clear, non-yellowing, film forming, water-borne acrylic sealer ideal
for use on interior/exterior, above-ground, vertical and horizontal
surfaces. This fast drying sealer has excellent hot tire resistance and
adhesion. Perma-Crete Plex- Seal WB is water resistant and seals the
surface while maintaining the natural appearance of the substrate.
Perma-Crete Plex Seal WB is ideal for use on concrete surfaces such
as garage floors, driveways, pool decks, walkways, warehouse floors
and more.
