I installed the Bosch 1 wire 02 sensor, but it had the clip on the end, no splicing. Engine seemed to run a little smoother and quieter.
The biggest problem with this car is that it SOUNDS like a beater, due, I believe to an exhaust leak. Everything seems pretty solid and intact on the exhaust. It appears that exhaust is escaping somewhere between the flanges where the catalytic converter bolts on. Is there a gasket here? Would it be best to just eliminate the cat?
