Where to get 1.21 Gigawatts of Power
SE British Columbia, Canada
Marty needed 1.21 Gigawatts of power for his Delorean in the 1984 movie Back to the Future. Where would you get that kind of power?
One answer is the Champlain Hudson Power Express that may be built from Quebec to New York City carrying hydro derived electricity. The line will have 1,250 Megawatts of capacity or 1.25 Gigawatts, enough to power up the Delorian with the flux capacitor.
Here is a map of the route. The interesting thing is much of it will be imbedded in a trench jetted into the bottom of Lake Champlain and the Hudson River. The rest will be buried underground.
Very cool. From what I remember Michael j Fox or Christopher Lloyd mispronounced "Gigawatt" as "jigawatt" so the producers left it in.
I had a prof in college (he would be in his 90’s now) who pronounced it the same way. Not sure if he was sticking to an old pronunciation or having a subtle laugh, as I could see him enjoying the movie.
Another prof, same age, didn’t like the change from cycles per second to Hertz. Yep, I got my cranky old man training early in life. :)
Funny he had a phot of edison, and Tesla wasn't on his hit parade...
Anyway, for how long ?
A handful of Pu isn't generating that power...so for the time element to actually charge something.
I reckon there's a few GW in my hand approaching a door handle, but for a nonething of a second...
Oh my - Wut could go wrong ?
A prof was explaining to us the difference between power and energy. He said "If you have a 1.5 kW toaster and run it for two hours, what's the result?"
The expected answer was 3 kW-hr.
The class clown piped up with "Burnt toast!"
My understanding is that at a peak, a typical lightning strike is about 250 million volts and 25,000 amps. So the peak power output of that strike would be in the terawatts.
But then again, it's very transitory. A capacitor soaks up energy, so we'd have to know how long it stays that way. We can rely on our wall outlet putting out a consistent, steady voltage and current because it's relatively small.
And Back the Future plays fast and loose with basic electrical issues. Maybe it needs 1.21 gigawatts, but what happens if the system gets more than a thousand times that power? It's probably going to blow up without some sort of regulator if the voltage can't be controlled. And even then it's probably going to blow up with that much power unless the regulator is the size of at least a bedroom. Then there's the question of energy (power x time).
I too prefer units of rpm instead of Hz, who did he think he is?
