I have a chip in the windshield which developed into a crack four years ago. It was patched when it was 3 inches long.
Today the windshield was iced. My wipers were wiping on solid ice when I was using the defroster full blast. It cracked all the way across, from the passenger side horizontally across. In my sight, it is a little above the hood line.
I looked up the Texas Inspection Code, it does not say anything about the windshield.
I guess you can pass w/o a windshield at all, but you need wipers.
A new windshield job would run $600+ (I have tinted band, dot matrix top, and wiring for the auto dimming mirror), my insurance deductable is $500.
Should I go for it?
Quote:
05.01 Inspect Every Passenger Car For: (Listed in suggested order of inspection)
* Check for evidence of Financial Responsibility
1. Horn
2. Windshield Wipers
3. Mirror
4. Steering
5. Seat Belts
6. Brakes (system) (Parking - beginning with 1960 models)
7. Tires
8. Wheel Assembly
9. Exhaust System
10. Exhaust Emission System (beginning with 1968 models)
11. Beam Indicator (beginning with 1948 models)
12. Tail Lamps (2); (1) if 1959 model or earlier
13. Stop Lamps (2); (1) if 1959 model or earlier
14. License Plate Lamp (1)
15. Rear Red Reflectors (2)
16. Turn Signal Lamps (beginning with 1960 models)
17. Head Lamps (2)
18. Motor, Serial, or Vehicle Identification Number
19. 1988 & newer - inspect for window tinting or coating
20. Gas caps on vehicles 2-24 model years old.
Should I go for it?
