I was at the Sun N Fun aircraft "fly in" and purchased a Whelen Par 36 LED landing light.
While I am not a huge fan of LED's yet, I purchased this because the standard GE landing lights have a lifespan of 10 hours continuous use. The LED lamp is certainly good for many more hours than that.
So, I can fly with the light on all day long for visibility, plus not worry about it failing when I need it most.
Anyway, the reason I posted this here is that some of you might be interested in the specs. It makes 1700 Lumens "out the front" and has a 10 degree beam spread. It is somewhat thinner than a typical Par36 bulb and a bit lighter too. It runs on 12V and draws a measured 1.3A for a total draw of 17W.
In other words, 17W gets you the equivalent of a HIR-2 "high beam" bulb. Or about half the theoretical output of a 35W HID setup. (can't really tell the difference visibly, they are all very bright)
Interestingly, this bulb would make a great motorcycle, dirt bike or ATV headlight. It's light, tough, impact resistant, and requires very little power. It would even make a great hand held spotlight/searchlight.
