Which products are you considering?
Originally Posted By: qwertydude
I'd say just wax the wheel with a high quality durable wax like Collinite. Before waxing, clay it to remove some of the bonded contaminants.
This will yield better looking results than hoping a temporary paint will end up looking good, more often than not they don't unless you prep the wheel really well for the painting, but if you get to that level of prep work you might as well just spray your wheels with another coat of real clear coat for extra added durability.
Plus Plastidip clear will end up matte looking. If you want your wheels matte, then yes go with the Plastidip it'll protect quite well and last a pretty long time and will peel off.
Claying the wheel takes way too long. I would use Iron-X or Sonax Full Effect, then either Hydr02 or coat the wheel.
