See it quite a few places where 2 panels meet or around some trim. Rubbing compound doesn't do much as it seems to be in the paint. Is it mold? How to remove?
Don't have any bleach but do have some mildew remover.A small dab of bleach with a q-tip would make mold disapear. I wonder if it could even be shotgun fungus from a nearby hardwood mulch. Never seen anything quite like it.
You must be on a phone.Wow, perfect circle, perfect elongated rectangle ( like a hockey rink) perfect dot. That’s weird.
If those spots are raised above the paint, it's not mildew or mold but likely shotgun fungus from mulch. If it's shotgun fungus, you won't get it off.Don't have any bleach but do have some mildew remover.
Isn't that like rubbing compound?Try Mr. Clean Magic Eraser.
Go lightly, with some water to dampen it.
60 grit on the pneumatic belt sander!Wow, perfect circle, perfect elongated rectangle ( like a hockey rink) perfect dot. That’s weird.
You can use Magic Eraser on suede , so not the same.Isn't that like rubbing compound?
Good luck then.No, its in the paint.
