Lubricating compound, brake lubricant, dielectric compound. Are they all the same silicone paste?
Then who makes a recommended silicone grease?I haven't look at the specs or SDSs, but don't believe the "Lubricating Compound" is pure silicone. In my (long ago) experience, it turns gummy with age, which silicone grease would not.
Looking for something to use on metal pins in plastic mounting holes so the metal doesn't rust-jack. And occasional spark plug boots
Like this stuff?
Or can I use Motorcraft PTFE I already have?
I've got the same old NAPA tube. Note it mentions squeaky fan belts. Wasn't that a topic here recently?
I got it for slide pins on the brake calipers. That's the only thing I got it for.I've got the same old NAPA tube. Note it mentions squeaky fan belts. Wasn't that a topic here recently?
https://www.amazon.com/s?k=mission+...ission+sil,aps,125&ref=nb_sb_ss_ts-doa-p_2_11Then who makes a recommended silicone grease?
I used GE silicone spark plug boot-release compound for a long time. More recently, I bought Super Lube® Silicone Lubricating Grease for slide pins, but haven't used any yet for that purpose. It contains PTFE. Their long list of claimed applications includes "brake parts." It worked great to lubricate the rubber mounting sockets of the Prius's plastic engine cover---as any other silicone grease probably would've similarly.Looking for something to use on metal pins in plastic mounting holes so the metal doesn't rust-jack. And occasional spark plug boots. Already use Permatex Extreme silicone ceramic paste for brakes.
Ended up ordering a bottle of this 3M stuff for spark plug boots and dielectric grease,
Will stick with this orange Permatex for everything brake related,
I quit using it for that reasonIn my (long ago) experience, it turns gummy with age
Yeah, me too. It is "gummy" and seems to dry out fast. I now use Mission also.I quit using it for that reason
