What's the difference between Mobil ATF fluids?
Dixieland
What's the difference between Mobil 1 Synthetic ATF and Mobil Delvac 1 Synthetic ATF?
Would you put one of these or Amsoil ATF in a 2005 F150?
M1 Synthetic ATF datasheet:
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Synthetic_ATF.aspx
Mobil Delvac 1 Synthetic ATF datasheet:
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENCVLMOMobil_Delvac_Synthetic_ATF.aspx
The fluids are very similar. The Brookfield viscosities are quite different too, interestingly. Delvac carries a lot of industrial vehicle approvals, whereas the regular M1 carries passenger vehicle approvals.
I would be inclined to run the regular M1 over Delvac since that carries the approvals your truck calls for.
I would use the Amsoil over Mobil 1 ATF. I have used exclusively Amsoil in my 5 vehicles including manual trans and full on race vehicles (5 total cars) for over a million miles without a problem. Longest run is on a 96 C1500 with 402k miles on the original trans with nothing but fluid changes every 100k (first at 30k with filter)
I have run Amsoil ATF on 4 vehicles with zero transmission problems. Also in two transfer cases and Amsoil SVG in many F & R diff.
While I feel the synthetic motor oils like T6 or M1 or Pennzoil Platinum / Pennzoil Ultra come close to Amsoil signature oils, I think the Amsoil is a step up from other synthetic ATFs.
Mobil Delvac 1 ATF is a Allison TES-295 ATF/Dexron III fluid. Uses Group IV base oil. Very good ATF, It's only purpose is to meet Allison specs.
Mobil 1 Synthetic ATF is Mercon V approved & Allison C4 approved...Making it a Dexron/Mercon fluid.
I agreed.
Since you change ATF once every 50-60k miles, the extra cost of Amsoil ATF over that mileage is less than a dollar per 1,000 miles.
I have used Mobil 1 ATF for 20+ years with no trans or PS pump problems. As for Delvac 1, no experience.
