What's the best tool to cut through metal rods?
TX
My gate metal rods are now scraping through gravel. Need to cut at least a portion of 5 rods.
Should I buy this tool from HF?
https://www.harborfreight.com/7-amp...5gpE_1IIW6ABFb_Xa_uKUVvVr-qbSPUhoCgGkQAvD_BwE
Thanks
Yep, hard to beat a angle grinder with zip disc for that.
AS Rand said thou, might want to see if the gate is sagging and maybe fix that instead?
The grinder you posted and this diamond cutting blade. I don't like self destructive blades as who know if there is asbestos in them, and if they don't, they still through micro powder in the air. Wear a high end respirator.
This diamond blade has a ton of industrial diamond at the cutting end so it is the fastest cutting blade I have found yet. They have 4, 4.5, 5, and 7 inch versions.
https://www.menards.com/main/floori...-blade/mf-vfl45/p-9115189600933118-c-6599.htm
What do you have now?
Are they solid or hollow? If there hollow just get a hacksaw, take 5 minutes.
If there solid then I would say sawzall over grinder cut off wheel - but probably depends on what tool you want to have for next time.
Can you take the gate off? If so you could use a cutting wheel on skill saw or jig saw if you have them already.
It looks like a heavy gate. It’ll be a lot easier to fix the post to which the gate is attached,
Asbestos? I thought it's been banned over several years ago
