What’s the best spark plug replacement for my Generac GP6700E generator?
NavyVet88
Site Donor 2026
Alabama
According to the manual, the part number for the factory plug is 0J00620106. Is the NGK 5534 the best replacement?
I’ve read several threads here pertaining to generator maintenance and lots of folks have said that NGK plugs were the best way to go. My generator is only about a month old right now with just 3.5 hours on the clock so I’m still working on the oil break-in at this point and was wondering if I should throw a better plug in it already.
Edit: if the NGK 5534 is gtg, I’ll grab one at Oreillys when I buy the next quart of oil for the break in change at 7 hours.
I use copper plugs. The gen set is on a set for the last 15 years. Runs once a month, three days after Mathew and on occasional power outages. Garden tractor has about 20 years. Take them out and still look almost new. Even have them in my vehicles. The thing that killed exhaust systems and spark plugs was leaded gas.
I ordered a four pack of the copper 5534’s online today. I forgot to update the post so my apologies. I’ll install one at the next oci l.
Here are the specs of the plugs you ordered. The gap should be .031" and they are good for 30K miles. It doesn't show hours.
https://www.ngk.com/ngk-5534-bpr7es-nickel-spark-plug
Although, iridium spark plugs have the best longevity, copper plugs have the best spark. That's why racing plugs are always copper. I wouldn't use iridium plugs on equipment (including motorcycles) that are speced for copper plugs. Just replace them after certain hours, as mentioned in the owner's manual.
Non issue. The only reason for exotic plug materials is spark plug longevity.
Not exactly :sneaky:
The thinner electrodes on iridium also allows for easier start and possibly better fuel economy. In a lawn lower, for example, or anything with recoil start where you have to pull the cord, you will definitely notice easier starting with iridium.
Unless you can support your theories, I think the difference in quicker starts is in the noise. The very minor difference in fuel economy might be because of less spark shrouding in the combustion chamber with iridium spark plugs. Again, in the noise.
I'll stick with the theory of longer plug life. 100k miles versus 30k miles between plug changes.
The longer life is also true. There is more than one reason :)
