Originally Posted By: alarmguy
If I am on cocaine, you must be on CRACK.
I ask only because you seemingly felt the need to intensely scream your point in our faces using not only all caps but bold text as well. As if by the very act of screaming that it made what you were trying to convey beyond reproach; that by yelling it somehow made your point that much more valid.
It doesn't.
Not sure what part of the tests above you are referring too.
Then perhaps you'd be best served familiarizing yourself with the API and ACEA testing protocols as a starting point. If you don't know what tests I speak of, but claim that a specific company does "best" in these standardized tests, how are we supposed to take you seriously?
But I bet, if you put a group of oils through the same tests you mentioned, one or two brands would come out on top on those tests.
I see you are unfamiliar with the concept of marketing. Are you aware that Valvoline uses the Sequence IVA (a recognized, standardized test, part of the API testing protocol) to claim the lowest wear?
Are you aware that the SOPUS claims about piston cleanliness are also based on one of the sequence tests? Yet another standardized test.
Companies advertise their performance in the tests they do the best in.
So what your rambling is about I have no idea.
That's quite obvious.
Amsoil ran a bunch of oils through a bunch of standardized tests and Amsoil came out in the top 2 or 3.
Maybe if you read the tests, you will understand, until that time, stay off the crack.
I've read the tests and comprehension is far from a weak point for me. I think perhaps you need to revisit what tests exist in the standard certification regimen and then ask yourself why a company would only choose to advertise their performance in a select few of them.
On top of that, the OEM testing protocols are far more demanding, particularly for the Euro marques. AMSOIL has only recently obtained some of these approvals on one of their Euro spec products, which was a welcome move for those of us that are dealers and were looking for an approved product that we could safely recommend for somebody with a BMW, Mercedes or VW. I have yet to use it in my current BMW, but I did use their Euro oil in the 328i we used to have.
Unlike you, I actually do actively use AMSOIL products, particularly their ATF and gear lubes. Their ATF has no VII's in it, making it a very good choice for PS fluid, which is an environment of high shear. But I also don't feel anybody's marketing is straight-up honest and this is why AMSOIL continues to use the completely meaningless 4-ball wear test, something that is designed for gear lubes and has no relevance to an engine. It is also a standardized test BTW, but not for motor oils
Well, then, why dont you answer the person who started this thread? My response was to him/her, not you.
I only say that because your condescending post full of words that mean nothing because you didnt answer the OP question.
Your reference to "more demanding OEM" tests mean nothing because there are no results. Your words "completely meaningless 4 ball wear test" mean nothing because you offer no results or alternative results of standardized tests of some motor oils to compare.
I offered the OP some standard tests to answer his question WHY Amsoil vs Mobil 1 etc. ... nothing is absolute but its all we can work with, that and used oil analysis, since everything else in the industry is smoke and mirrors and lets not forget royalty payments for stamping a product that meets an OEM spec that most oils will also meet..
At times, more so with motorcycles, there is a correlation in the used oil analysis when compared to the Amsoil results in their tests. Besides tests, everything else is smoke, mirrors and meaningless words. More or less, no need for an oil forum, just buy whats on the shelf at any price as long as your OEM stamp is on it, your good to go. But honestly, that goes for any API rated oil, engines will far outlast the vehicles but some, like myself have fun picking a well rounded product that MIGHT give me an extra edge over the others.
