Oh yeah, the cold start season is here. Let the cold start rituals begin.
You'd be surprised what percentage of car owners in this country have to bring the champagne out every time they are able to simply park within walking distance of where they live, and have seen things like garages, driveways, or dedicated parking spots with electric outlet access in sitcoms and movies only.If it's cold, keep your car in a garage. If you don't have a garage plug in your block heater. If you don't have a block heater get one.
If your location is that densely populated, you probably don't need a car very often. I think his broader point is still valid.You'd be surprised what percentage of car owners in this country have to bring the champagne out every time they are able to simply park within walking distance of where they live, and have seen things like garages, driveways, or dedicated parking spots with electric outlet access in sitcoms and movies only.
Let them not eat cake.
The Subaru indicator is not about waiting till it goes off. It’s more about driving gently when blue, once off you can operate normally.I can only tell you what was told to me in GMTC powertrain classes after we asked an engineer. It’s best to drive off easy when the coolant temp reaches about 120f. So depending on starting temp the warm up time varies.
Many years later when I bought my 2013 Subaru Forester, which has a blue cold engine light, I hooked up my scanner and it turns off at 120f. Coincidence??
Most such areas require the car moved once or twice per week if parked publicly. Even if you don't use it often, when you use it is one of those times you need it warmed up. Short trips to change parking spots etc.If your location is that densely populated, you probably don't need a car very often. I think his broader point is still valid.
What vintage is your Infiniti? Perhaps it may do it to mine but they're older stuff. That is nice Nissan has incorporated that into your ECU. Could certainly help w/trying to be easier on the transmission. Just got done watching an older Q45 YT video the other day.. I just need enough cash to buy a new 25' Q80 & I'll be set w/the family.When it's colder outside, my Infiniti will fast idle at 2000-2100 rpm and the slightest movement of the gear selector triggers something that tells the ECU to lower the RPMs but only by ~500 rpm or so. If I put it into D at 1500-1700 rpm, it's not a nice jolt on the transmission. It will stay at up to 2100 rpm for 2 minutes or longer on it's own too.
Hey, if we had a remote start I'd do the same. As of right now my wife is the "Remote Starter" but I've done my work.At home, we park in our garage so it's not that bad. At work, I'll start mine and let it warm up (the interior) for 5 minutes routinely. My wife remote starts her car, then has a ~10 minute walk. If she's paying attention to her phone app and it tells her it shut off after it's time limit, she'll restart it !![]()
I didn't have a garage for my first 40 years. And I was starting my cars in -20F (and colder) weather. But I did have a block heater, and I used it every cold night.You'd be surprised what percentage of car owners in this country have to bring the champagne out every time they are able to simply park within walking distance of where they live, and have seen things like garages, driveways, or dedicated parking spots with electric outlet access in sitcoms and movies only.
I find the best way to start a vehicle with a manual transmission is with the clutch depressed. When I release the clutch a few seconds later (transmission in neutral) the engine slows for a few seconds.Fire up, let it run until hopefully the windshield is clear and it's not crazy cold in the cab. That might be a few minutes or let it stay running all day. When it's -60* and blowing, the cab isn't staying that warm.
Plus everything else that's hooked to the engine.
I've had to put the transmission in gear and T case in neutral to get that to flow. And rear end oil may as well be glue... to the point you can take the diff cover off and it doesn't flow out.
That's a perfectly valid approach-- for Arizona.I start the engine, fasten my seat belt and then I go. Fastening my seat belt is my way of timing the warm up period. The car only has 355,400 miles on it and does not burn oil, so we still need to see if my method is any good.
Beltronics RX65 startup sequence, for the win !!!You know - I just realized that I do start the engine and wait for the radar detector to announce all it's radar band tests and that GPS is connected. So maybe that is ten or fifteen seconds. <g>
I used the same approach when I lived in Western Washington. It gets surprisingly cold in the winter here. Our home is at 3,600 feet.That's a perfectly valid approach-- for Arizona.
Yes, coincidence. I suspect it's actually 50C (122F) as almost nobody does engineering in English units-certainly not Subaru. You'll find round numbers in SI are quite common. But not in any natural process.I can only tell you what was told to me in GMTC powertrain classes after we asked an engineer. It’s best to drive off easy when the coolant temp reaches about 120f. So depending on starting temp the warm up time varies.
In over 40 years driving manual transmission, I can't recall any of mine that didn't have a clutch interlock and it had to be pushed down.I find the best way to start a vehicle with a manual transmission is with the clutch depressed. When I release the clutch a few seconds later (transmission in neutral) the engine slows for a few seconds.
