Hi Everyone,
I've been lurking for a while just reading, now I'm hooked. I have learned SO much from this forum! In fact, since I started hanging around here I've started changing my own oil again....for the first time in 30 years!
I'm driving a 1998 F150 Supercab, 2 wheel drive, 4.6 liter V8, automatic with 112000 miles. I bought it new in 1998 and have always had the oil changed every 3 months or 3000 miles and have always stuck to the factory recommended 5w30.
Two months ago, mostly because of Bitog, I decided I wanted to change my own oil again. Due to the recommendations I found on this forum I went to Wal-Mart and picked up six quarts of Motorcraft 5w20 synth blend and a Motorcraft fl820s filter. I also picked up a grease gun and some chassis lube. Yeah, it was kinda fun.....
Now I've found the Valvoline/Oreilly rebate, here on Bitog, and would like to try some Valvoline synthetic....for about a dollar a quart!
I live just outside Houston, truck has had regular flushes on transmission, coolant, injectors over the years and is otherwise decently maintained. Right now I'm only putting about 500 miles per month on the truck and I'd like to extend my oil changes to about every six months.
Ok, finally, my question. I ran 5w30 dino for almost 12 years. The last oil change I put 5w20 synth blend in it and it seems to be doing just fine! But, if I go to Valvoline synthetic, what weight would you guys recommend?
Thanks,
Larry
Thanks,
Larry
