What to use on squeaky garage door hinges?
Michigan
What do you guys recommend to lube garage door hinges? I'm thinking maybe white lithium grease in a spray can? Obviously I want something that's not going to drip on the car (or the garage floor)
On ours I thought about the same drip concern and went ahead and liberally used the cheap stuff in the oil can anyway. Then I ran the door up and down a couple of times, cleaned up a couple of drips, and it hasn't dripped since.
Yea white lithium is ugly but it works. Its a garage door hinge, so who cares about esthetics?
Put a puff of graphite/graphite equivilant powder in there before the grease. The door hinge isn't a precision hinge, so the bulkier graphite will help.
For me....it's a dab of Red Lithium grease on each hinge....front and back.....rub it in well on each side of the hinge and the squeak will be gone....you only need a little to get in between the hinges.
IMO....red lithium grease lasts a long time. I still have it on the T4R door hinges and hood and back latches.
Spray oil etc......does not last and you will have to reapply over and over again.
Sae250 mixed with motor honey or Lucas.
It's tacky, so it sticks.
I can't in good conscience use either in anything with a motor...but it works great for lubing hinges. Doors, trailer gates, anything that sits in the weather.
Stuff works great and I've got 5 gallons mixed up.
Originally Posted By: Donald
PB-Blaster makes a lubricant just for that. Are we talking hinges or rollers? The rollers do wear out.
Pretty sure its the hinges. Hadn't really paid any attention to them in the 2.5 years we have lived here but while installing a new garage door opener I noticed the hinges look like they haven't ever been lubed. The door has always been noisy even after the old GDO quit working a while ago. Guess I should check the rollers too while I'm at it.
Zep makes a clear spray grease 2000 that sprays in & thickens up. LPS1 or dry spray graphite, or teflon is good on hinges & lps1 also good on locks don't attrack dust & provides a moisture repelant dry lube
Used fluid film on the hinges, rollers bearings and the main spring a few months ago and it has worked great in the squeaks and creeks but we all see how it holds up I guess.
