Hello, I am looking for recommendations for the type of oil for both of my mid 2000 Chevy road warriors.
1. What kind of vehicle you have
2004 Suburban flex fuel 2 wheel drive L59 engine
2005 Silverado Z71 4X4 L59 engine
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well
5W30
Your vehicle’s engine requires oil meeting GM
Standard GM6094M. You should look for and use
only an oil that meets GM Standard GM6094M.
3. Where you live
Memphis, TN The suburban see's Wisconsin sub zero temps for a week out of every year.
4. How you drive (easy? hard? fast? slow?)
easy
5. What your daily drive is like (short trips? long trips? city? highway?)
Daily short highway trips for the silverado and car rider lines for the suburban.
6. Whether your car has any known problems
None
I bought the suburban with 80,000 miles. OCI was changed according to the oil system monitor. Oil used was Mobil 5000. Engine currently at 177,000 miles. Last oil change and based off what I loosely read here, I found and used Motorcraft 5w30 from walmart. Price was $17.97 vs $12.88 for the Mobil 5000
Silverado was bought with 225,000 miles. I have since swapped out the motor Lm7 to L59 with LM7 intake and injectors. My old motor began to tick aggressively due to a failed lifter which is common on the LS motors. The replaced motor in it that has 80,000 miles. The guy that put the motor in used Mobil 1 synthetic. I am due for my oil change now. Was thinking of going with the MC 5W30 as well.
Thanks for all the info. in advance.
5W30
3. Where you live
easy
None
