What Oil Is Best To Clean Engine Varnish
New Jersey
What oil or additives does everyone like to help clean a 2004 chevy Blazer 4.3 vortec
It has a lot of varnish... I have mmo in there now
I have had some success with Pennzoil Platinum, you may want to give Pennzoil Ultra a try as it seems to have a little bit more cleaning additives than the PP.
sludge or Varnish?
Varnish does NOT hurt anything and 99% of engine will have some.
Best cleaning oil IMO is redline. Ultra would be a good bet also
Since I am a 32 year veteran of M1 so I have never had sludge or varnish, so I'm not sure how it is for removing varnish, but it is outstanding in preventing it. My engines stay very clean even with high mileage.
Do an Auto-Rx treatment.
+1. Auto RX is a great product that will remove the varnish. Even though its not harmful.
Show me ONE post on BITOG that indicates that Auto-RX has removed varnish.
Originally Posted By: calvinnnnnnnnn
anything loaded with calcium(2900+ ppm) and sodium
pennzoil Platinum, amsoil, ultra
That doesn't make much sense as written. Just because an oil shows Ca, or Na in a used oil analysis does not mean it will clean sludge. Ultra? How do you have proof it cleans sludge?
+1
AND there is no proof amsoil does either.
i was not referring to sludge nor was op
anyways, op if you want to clean up your engine naturally, do short intervals of synthetic. some may say its a waste of money but it can clean it up.
here are my results of running 20k miles on synthetic:
http://www.bobistheoilguy.com/forums/ubb...169#Post1773169
+2 sludge or varnish does not matter I agree.
Redline did a nice job with the very slight discoloration that I saw when looking through the oil fill hole on my '96 3.8L Ford Windstar.
I took the valve covers off for the first time a couple of weeks ago......and things look pretty good at over 220K miles
2953947960011220610AwaHND
Hi,Steve S. i have not seen you on in a while glad to see you online it has 187,000 miles and it is a little dirty i dont knoww if i should put PP in such a high mileage engine...
Originally Posted By: znode
Acetone, wire brush, and elbow grease.
Just saw a nice read up on this:
Quote:
Cleaning may be accomplished using mechanical (abrasive), chemical (heating, solvents, pickling with acids) and electrolytic (electrocleaning, electrostripping) means.
Sample procedure:
1) Anneal and pickle in suitable acid.
2) Rinse 3-5 times in running water.
3) Dip into simmering ammonia and detergent solution and scrub well.
4) Rinse well 5 - 10 times.
This is a sure-fire way to clean ALL the varnish!
I wholeheartedly disagree with those that think varnish is benign. Varnish buildup:
- slows heat transfer to the oil causing the engine block, etc to run at higher temps
- narrows oil passages, causing reduced oil flow
both of these, over time, reduce engine life.
As far as cleaning up Varnish, motors oils are focused on preventing it by reducing oil oxidation, not cleaning it up after it has already occurred.
MMO and Rislone would be good products for cleaning it up, but I like MMO much better (ARX does nothing for varnish) - so stay with the 1 qt substitution of MMO per OCI you are doing and after an OCI or two (depending on how much you have), it will clean it up.
I aquired a 2000 4.3 vortec a few years back that had been getting bulk oil at the most convenient speedy lube all its life. I was not happy with the cleanliness so I've been running Pennzoil Platinum and it has seemed to clean up nicely from what little I can tell with a flash light through the fill hole.
