What oil for a 60's Briggs
I am not looking for the viscosity of the oil. I was thinking about an oil that would have additives more in line with the time of manufacture of the engine. Correct me if im wrong, but dont todays oils have lesser amounts of things like zink that would protect an engine design of that era ?
So, what say you to the best oil for the 60's 9 HP B&S on a 3500 Watt generator?
And what temperaure range would that/those oil(s) be good for?
Straight 30 has limits to how low of a temperature it is good for. Multi grades (not synthetic) loose ability with hot ambient before a single grade would.
I still prefer the synthetic 5W-40 HDEOs because they have the additive pack, operational temperature range for air cooled engines, shear stability, and leeway for inevitable shear without compromising cold weather performance or being so thick as to impede cooling on the hottest days. The HDEOs are also meant to handle lots of soot and contamination, far more than PCMO.
IMO, the OP should do his homework looking at used oil analysis from older diesel engines and compare these used oil analysis to HTHS and other metrics of the oils in question. VOAs are nice to see, but they tell you very little about how fit for use an oil is. While we know that zinc and other additives are one good ways to provide the protection needed, I think the OP would do himself a disservice to make the decision based on their presence in a VOA. There are many additives that can accomplish the feat of providing this protection and the only real test of their ability is to look at used oil analysis from engines that are known to be hard on oil or have flat tappet cams.
That being said, I chose RTS for mine and would recommend the same without hesitation.
I use it in my 1984 8hp 3600RPM Briggs mounted on a Coleman generator. It's been through a few hurricanes and some other stuff, too. Still runs like new. It's only ever run RTS and Mobil 1 10w30 (Previous owner).
Excuse my ignorance but what does the RTS stand for? (shell rotella?)
Would Rotella T Synthetic 5w40 be ok to run in a modern 25 hp Kohler twin? The manual does not list anything over a 30 weight. Using 1 oil for both would simplify things.
Yes, I think it would be fine. And, yes, RTS is our BITOG acronym for Rotella T Sythetic 5W-40. I think anything over a 40 would be overkill though, especially in a system like the Kohler. If I were you, I'd buy it by the gallon and look for either the older CI-4+ or the new "T6" CJ-4 variant. The T6 will be easier to find, probably.
posty, not sure what part of NY you are from but in the Albany area, I just saw jugs of Pennzoil High-Mileage 10W-40 in the Glenmont Walmart for $7. Can't beat that!
