With a coil spring type bypass valve, additional pressure force above the cracking pressure isn't going to result in a "fully open valve". The coil spring has a spring constant that will make the bypass valve open progressively with added pressure force on the valve. It's not like the valve just snaps to fully open once the bypass pressure is reached and the bypass valve starts cracking open.
Yeah, the Purolator "flat spiral spring" is a different setup. There was a member here that also did some opening pressure testing on those here. Don't recall who, but I bet if I ping
@Sayjac he can provide the link to that thread like he has in the past.
