What oil are vq37 owners using?
I've heard good things About magnatec. We used gtx for a bit on the first gen Highlander but went Mobil 1 high mileage which cut back on the oil burning there
Magnatec is no longer offered by Castrol. Thought is they simply renamed it to the "GTX Full Synthetic" you're seeing. I buy my oil at Walmart and it seemed like GTX just swapped space with Magnatec.
Either are fine. The VQ engine design is rock-solid reliable and almost 25 years old. Real-world has proven it's not picky about oil.
I have heard Ester based oils quiet it down a bit but it's minor and not a reliability concern from my understanding
My VQ35 and VK56 have been pretty happy with 5W-50 in NC. This time it's Amalie Elixir 5W-50, but I use plenty of other 40/50 grade oils. SuperTech Synthetic 15W-40 is my favorite.
Thought the group v stuff was ester based. Nissan sells a ester oil but I hear it's exaggerated
Some oils utilize small amounts of various esters in the formulation but there are no ester based automotive engine oils.
And just so you know, Group V base stocks are anything that doesn’t fall into Group I-IV, so it’s not just an ester compound.
There aren’t any ester based automotive engine oils.
Nissan does "recommend" an ester-based (no idea what that means, nor do I care) engine oil in the owners manual, but the only easily available oil is Nissan's own, at least that I know of. I've never looked for it anyway.
Not a VQ37 owner, but a VQ owner non the less. When I had my Pathfinder and Xterra equipped with the VQ40 I used Mobil 1 0W40 almost exclusively. I put a combined 400k miles on them without issue. Can’t go wrong with Mobil 1 0W40 in my opinion.
What do like about that oil, besides the price?
When used hard (spirited driving, or towing, etc.) my timing chain engines start to get more audible as the oil gets thinned down. Or simply due to miles on oil interval.
With 15W40 that doesn't happen.
And being synthetic it also doesn't rattle on cold startups. Non-synthetic Mobil or SuperTech oils do rattle a bit more when cold, for example.
Also being an HDEO - it usually comes with higher ability to keep soot and combustion byproducts in suspension, compared to most PCMOs. So higher MOFT, better shear stability, and better cleaning abilities are what I love about it, and my wallet loves the price.
I used to be an "Mobil 1 0W40 in everything" guy, but in my usage, climate, and equipment I have yet to find a case where Mobil 1 0W40 outperforms SuperTech Synthetic 15W40.
So what about stuff like motul and liquimoly? I always saw liquimoly as gimmicky but idk
liquimoly is a joke. most of their products are either snake oil or very overpriced (mostly group 3, hydrocracked oil, on par with $4-5/qt products made in the US but with "it's german" markup).
motul makes some nice stuff, some mediocre stuff. nothing i think is worth the extra cost for street driving.
Nissan uses a coating called DLC which is supposed to bond to the ester oils and create a barrier thus lowering friction/wear.
https://www.nissan-global.com/EN/INNOVATION/TECHNOLOGY/ARCHIVE/DLC/
https://motoiq.com/nissan-370z-bad-...ge-engine-clatter-and-more-hype-or-reality/3/
I know the engine variant is different, but in the M35 that I owned for 17 years and recently sold, I used several name brands without any issues, but the motor seemed to run quieter with SOPUS oils, Pennzoil and Quaker State 5w-30.
Yea as soon as I saw green oil I was like ok idk about this. Who cares if it's green going in?
Interesting to know about motul. Used to see it at some dealerships like Subaru alot and was always curious
