What is trlinium?
the Netherlands
Hello,
I have question. What is trilinium?
Is this a commercial name or real product. What are the physical and chemical properties of this additive.
Additional info - It come across when I read article over DuPont "Finish Line" products.
Mister google does not help me a lot and I decide to ask the chemical specialist in this forum.
Thanks in advance
Miro
I looked in Google also...it seems to be a made up chemical-like name. Or an online electronics store.
Its not a DuPont product. Its a Finish Line ( http://www.finishlineusa.com/ ) product.
They use Teflon, and Finish Line NEVER mentions "trilinium" anywhere on their label or ingredients or marketing material. Never.
Thanks,I know that they use trlinium in their dry chainlube but now I sow the same component in their grease. This grease is famous in bicycle brache. It makes wonder in any hub.http://www.finishlineusa.com/downloads/product-information-sheets/Teflon_Grease_Info_Sheet.pdf
Where have you ever seen the word "trilinium" used in association with any of Finish Line's products, either dry lube or greases? They only mention they have Teflon, thats all.
You might have seen Niagara Cycles, an online retailer of bicycle stuff, accidentally add the word trilinium to their website, but its not part of the product.
They stole it from McDonald's...Special Sauce.
Trilinium is rendered from Platformate. Shell Oil charges a hefty royalty but it doesn't add too much premium due to the small amount used in greases.
Have you heard of Royal Purple's, "Synerlec®?"
Have you heard of Schaeffer Oil's, "Penetro®?"
Have you heard of Lubrication Engineer's, "Almasol®, Monolec®, Duolec®, or Quinplex®?"
They are all Marketing (Hype) names given to certain lines of additive packages.
Add some Star Trekky or Star Warry geekish syllables and you have a Marketing (Hype) additive name.
https://en.wikipedia.org/wiki/List_of_Star_Trek_materials
I'll go with secret sauce it has a certain ring to it. M1 oil with secret sauce. Secret sauce is used to prolong the life of NASCAR engines . Secret sauce reduces engine wear during start up and heavier loads, increases horse power and Miles per gallon as well as stabilizing the oil and reducing emissions.
