What is this part called
San Antonio, TX
1999 Mercury Tracer The pcv hose and 2 other vacuum hoses connect to this part on top of the intake manifold(I know the picture is of the engine). You can see the pcv left of the red and white sticker. What is the pcv hose connector on top called? Thanks!
Manheim, PA
That is the identical setup to my 99 Escort. Those are actually 2 coolant hoses coming up there from your heater core hoses. The metal PCV fitting and the piece the 2 hoses connect to is serviced with the intake. If it is broken, you will need to replace the whole intake manifold assembly.
