Yep, everything ToyotaNSaturn said is correct. Also,quote:
Originally posted by ToyotaNSaturn:
Need? No. Want? Yes.
Lube Control fights oil oxidation breakdown, allowing the oil to due it's job: lubricate. All factors being equal, you'd see a lower "insolubles" level in an UOA when used as per it's directions.
I've been using it since last year. It's VERY cheap all in all, and can help many oils, including good synths, do a better job and last longer. There was someone who was going to go 10K on dino with LC and post a UOA. I wonder if that's in progress or not...
Auto-Rx is the thing to use to clean a sludge-ball engine. Essentially, Lube Control is used to keep an engine clean, Auto-RX is used to make it clean.
My thinking observation is this: after you use Auto-Rx to clean an engine, continue with LC for the duration that you own the car. You'll probably never need Auto-Rx again in that engine in my opinion. However, most won't follow the regimen like most of us BITOG'ers, so Auto-Rx may be warranted every 30-50K to keep things VERY clean. Especially in Toyota's 3.0L, Dodge's 2.7L, etc...
Wow, that was fast!quote:
Originally posted by Airborne Ranger:
That person who is going to test LC with 10K on cheap dino oil would be me. This spring/summer I plan on using the cheapest detergent 5w30 I can find on the shelves, run it with LC then UOA. I can go more into detail about this but this is not the title of this thread,,,,,AR
Yes but my manual states that you shouldn't use any oil additives and that they may void your warranty. Also, if a synthetic is great basestock oil w/ a robust additive package (like GC) why would you need this? Especially in a new engine. What exactly IS lube control? Is it a synthetic ingredient?quote:
quote:
To keep the oil doing it's job...lubricating the engine while keeping the junk at bay. The gunk that oils accumlate (namely insolubles) is lessened by LC's formulation. Thus, allowing you take the oil to MUCH longer drains. I feel that GC in many applications can go 15K with LC, though few ever do go that long.quote:
What is a unscientific observation?quote:
Very unscientific observation.
Below is the first UOA of petroleum oil (Havoline) with LC for 10,000 miles.quote:
Yep, everything ToyotaNSaturn said is correct. Also, That person who is going to test LC with 10K on cheap dino oil would be me. This spring/summer I plan on using the cheapest detergent 5w30 I can find on the shelves, run it with LC then UOA. I can go more into detail about this but this is not the title of this thread,,,,,AR
